Can not do TryOutuClinux!
This days, I am trying to resolve the problem about running the uClinux in Altera Nios dev board, mentioned in my last post, so many methods I've tried, even followed the steps in TryOutuClinux in nioswiki, but there is only one result, failed. here is the information system gives me:
>>Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
>>Pausing target processor: not responding.
>>Resetting and trying again: FAILED
>>Leaving target processor paused
I am so sad with this problem.
I am afraid the dev board is broken, that will be terrible.
Anyone got idea?
Did you upload the correct FPGA config?
Which Altera Dev board do you use?
Did you config FPGA sof before download program , as Helmchen said?
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Which Altera Dev board do you use?[/b]
--- Quote End ---
The dev board is Nios Development Board, Stratix Edition, with A Stratix EP1S10F780C6 device, 8 Mbytes of flash memory, 1 Mbyte of static RAM, 16 Mbytes of SDRAM.
--- Quote Start ---
Did you config FPGA sof before download program , as Helmchen said?[/b]
--- Quote End ---
Of course, first of all, I download the standard .sof file to config FPGA, and then do the procedure:
nios2-download -g zImage_std_1s10
this is OK!
nios2-terminal
the error comes!
I updated the zImage_std_1s10. Please check again. And what is the error message of nios2-terminal ?
--- Quote Start ---
And what is the error message of nios2-terminal?[/b]
--- Quote End ---
$ nios2-terminal.exe nios2-termial: connected to hardware target using JTAG UART on cable nios2-termial: "USB-Blaster ", device 1, instance 0 nios2-termial: (Use the IDE stop button or Ctrl-C to terminate
And not responsing any more!
--- Quote Start ---
I updated the zImage_std_1s10[/b]
--- Quote End ---
Got it! Thanks for your help, hippo!
But still won&#39;t work. Is there any possibility that my dev board has some problems?Two weeks ago, I could download the image and the uClinux system run well.
Did you add -g option to nios2-download?
What is the message of nios2-download?
--- Quote Start ---
Did you add -g option to nios2-download[/b]
--- Quote End ---
yes, I add the -g opting when I use nios2-download command
--- Quote Start ---
What is the message of nios2-download?[/b]
--- Quote End ---
[SOPC Builder]$ nios2-download -g zImage_std_1s10
pausing target processor: OK
Downloaded 1196KB in 16.8s (71.1KB/s)
Verified OK
Starting processor at address 0x11500000
Please try a Hello world example on IDE/HAL running from SDRAM.
Hi, hippo,
I build the hello world project with the standard .sof file in
C:\altera\kits\nios2\examples\verilog\niosII_stratix_1s10\standard, and following is the result!
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Hello from Nios II!
That seems good. It looks like the sdram works.
I have already reinstalled the Quartus and Nios IDE, but uClinux can not be booted
where is the problem?
hippo, I also build a memory test project with the standard .ptf file, and it runs in IDE. This project can test flash, sram and sdram in dev board.
type, begin address , end address, size
flash 0x00000000 , 0x008FFFFF, 8M
sram 0x02000000, 0x020FFFFF, 1M
sdram 0x01000000, 0x01FFFFFF, 16M
The flash and sram are OK, but when I test the sdram, nothing responsing. The following is the information in console.
nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)             <---->   Nios II Memory Test.   <----> This software example tests the memory in your system to assure it is working properly.  This test is destructive to the contents of the memory it tests. Assure the memory being tested does not contain the executable or data sections of this code or the exception address of the system. ----------------------------------      Memory Test Main Menu ----------------------------------     a:  Test RAM     b:  Test Flash     q:  Exit ---------------------------------- Select Choice (a-b): b Enter the name of the CFI flash device to be opened, or just press <enter> to open "/dev/ext_flash") > -Successfully opened /dev/ext_flash -Region 0 contains 128 blocks. -Checking Region 0 for erased blocks. -Block 92, at address 0x5C0000 is erased. -Would you like to test this block? (y/n)y -Starting Flash Test. -Testing "alt_write_flash" and "alt_read_flash".    pass 1 - passed.    pass 2 - passed. -Testing "alt_erase_flash_block".  passed. -Testing "alt_write_flash_block".  passed. -Testing unaligned writes.  passed. -Returning block 92 to its erased state. -Flash tests complete. -Closing flash device "/dev/ext_flash". ----------------------------------      Memory Test Main Menu ----------------------------------     a:  Test RAM     b:  Test Flash     q:  Exit ---------------------------------- Select Choice (a-b): a Base address to start memory test: (i. e. 0x800000) >0x02000000 End Address: >0x020FFFFF Testing RAM from 0x2000000 to 0x20FFFFF -Data bus test passed -Address bus test passed -Byte and half-word access test passed -Testing each bit in memory device. . .  passed Memory at 0x2000000 Okay ----------------------------------      Memory Test Main Menu ----------------------------------     a:  Test RAM     b:  Test Flash     q:  Exit ---------------------------------- Select Choice (a-b): a Base address to start memory test: (i.e. 0x800000) >0x01000000 End Address: >0x01FFFFFF Testing RAM from 0x1000000 to 0x1FFFFFF
No result about sdram! I tries many times and got the same thing.
