12748 Discussions
Can not modprobe any driver
Hi guys
I have strange situation. Some time ago I realized that I can not load any module to Linux (I'm working with MMU). I wrote then simple driver to check:
# include <linux/init.h># include <linux/module.h>
static int __init hello_init(void)
printk(KERN_ALERT "Hello module is running\n");
return 0;
static void __exit hello_exit(void)
printk(KERN_ALERT "Hello module is exit\n");
module_init(hello_init);
module_exit(hello_exit);
When I use this drives as module in configuration, I put modprobe hello and system hangs. But when I add this driver to the kernel as static driver this driver is loading without problems. I see on the console:ttyJ0 at MMIO 0x4001450 (irq = 2) is a Altera JTAG UART
console [ttyJ0] enabled, bootconsole disabled
ttyS0 at MMIO 0x4001400 (irq = 1) is a Altera UART
hello module is running
mice: PS/2 mouse device common for all mice
TCP cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 2720k freed (0xc21cd000 - 0xc2474000)
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
BusyBox v1.16.2 (2013-06-14 13:30:28 CEST) hush - the humble shell
Enter 'help' for a list of built-in commands.
root:/>
What is here going on? Why I can not load any driver? When I use insmod the situation is the same... :/
--- Quote Start ---
--- Quote End ---
Please refer the next once.
http://www.alteraforum.com/forum/showthread.php?t=18802&page=5 # 48
Kazu
That's great! :)
I made changees as you mentioned in kernel.c for using kmalloc intead vmalloc and now loading modules is working.
But this situation is really really strange. I used insmod while I was programming my module for custom hardware in FPGA in two last weeks. I loaded modules via NFS. Everything was ok... When my driver was finished I changed to put it into the kernel and I didn't use dynamic loading. And sometime ago I tried load the driver again and it was not working... I didn't know what was going on. But now when I made changes as you Kazu said it comes back to work... But befere it wokrs with vmalloc I think..
