12748 Discussions
Can't boot uClinux from the EPCS & CFI Flash?
According to the
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174
When I try the 7th step ,I found can't boot uClinux from EPCS & CFI Flash,the prevous step is OK.
The problem of boot from EPCS:
the nios2-flash-programmer of zImage is OK,when reset the system,the Hardware may be configured successfully,but how Do I know the uClinux is start successfully?
The problem of boot from CFI Flash:
when use the nios2-flash-programmer programmer ,it promot:input file is too large to fit,and how Do I know the uClinux is start successfully,too?
Is someone have pass the step successfully? Need your help!
Thanks!
--- Quote Start ---
originally posted by gaobing@Jul 6 2006, 05:37 PM
according to the
when i try the 7th step ,i found can't boot uclinux from epcs & cfi flash,the prevous step is ok.
the problem of boot from epcs:
the nios2-flash-programmer of zimage is ok,when reset the system,the hardware may be configured successfully,but how do i know the uclinux is start successfully?
the problem of boot from cfi flash:
when use the nios2-flash-programmer programmer ,it promot:input file is too large to fit,and how do i know the uclinux is start successfully,too?
is someone have pass the step successfully? need your help!
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16684)
--- quote end ---
--- Quote End ---
Please read in the middle of the nios wiki, about DE2 difference,
http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/flashprogrammer)
