Can't open PTF file
Hello all
I have modified cpu cloclk to 100Mhz in SOPC Builder and cup input singal conneted from c1 of SDRAM PLL,then generate new ptf.
But I could not open PTF file under uClinux-dist-test dir.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
[faye@localhost uClinux-dist-test]$ make linux_hwselect SYSPTF=nios_clk100.ptf
KCONFIG_NOTIMESTAMP=1 make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-  ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x hwselect
  no emulation specific options.
make[1]: Entering directory `/home/faye/uClinux-dist-test/linux-2.6.x&#39;
  RUNNING hwselect
ERROR: Could not open SYSTEM ptf file.
make[1]: Leaving directory `/home/faye/uClinux-dist-test/linux-2.6.x&#39;[/b]
--- Quote End ---
Do you know how to solve this problem ?
Thx !
--- Quote Start ---
originally posted by jay_1025@Jun 21 2006, 06:52 PM
hello all
i have modified cpu cloclk to 100mhz in sopc builder and cup input singal conneted from c1 of sdram pll,then generate new ptf.
but i could not  open ptf file under uclinux-dist-test dir.
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
[faye@localhost uclinux-dist-test]$ make linux_hwselect sysptf=nios_clk100.ptf
kconfig_notimestamp=1 make arch=nios2nommu cross_compile=nios2-linux-uclibc-  arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x hwselect
make[1]: entering directory `/home/faye/uclinux-dist-test/linux-2.6.x&#39;
  running hwselect
error: could not open system ptf file.
make[1]: leaving directory `/home/faye/uclinux-dist-test/linux-2.6.x&#39;
--- Quote End ---
Thx !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16313)</div>
[/b]
--- Quote End ---
Please give the path of the ptf, eg, SYSPTF=~/proj_100/nios2_clk100.ptf
--- Quote Start ---
originally posted by jay_1025@Jun 21 2006, 01:52 PM
hello all
--- quote end ---
--- quote start ---
  running hwselect
--- Quote End ---
Thx !
[/b]
--- Quote End ---
As you notice, the make program enters directory home/faye/uClinux-dist-test/linux-2.6.x and runs hwselect from there, so that&#39;s where the ptf needs to be. Copy the ptf there, or give the absolute address of the ptf, something like SYSPTF=/home/faye/uClinux-dist-test/nios_clk100.ptf, or like hippo said, ~/project/nios_clk100.ptf.
--- Quote Start ---
originally posted by repa+jun 22 2006, 12:58 am--><div class='quotetop'>quote (repa @ jun 22 2006, 12:58 am)</div>
--- quote start ---
<!--quotebegin-jay_1025@Jun 21 2006, 01:52 PM
hello all
--- quote end ---
--- quote start ---
  running hwselect
--- Quote End ---
Thx !
[/b]
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16328)</div>
[/b]
--- Quote End ---
hello hippo & Repa
Thanks very much !
I can open PTF file now that two questions about open PTF file.
Q1:
I use this way to open PTF is OK in linux-2.6.16.1(buildroot) with no path.
Q2: Why I can open anthor PTF file in uClinux-dist-test with no path?
such as following
--- Quote Start ---
[faye@localhost uClinux-dist-test]$ ls
autoconf.h   Documentation  linux-2.4.x      README        uClinux-dist.diff.gz
bin          freeswan       linux-2.6.x      romfs         user
config       images         Makefile         SOURCE        vendors
config.arch  include        nios_605.ptf     system_0.ptf
config.in    lib            nios_clk100.ptf  tools
COPYING      linux-2.0.x    openswan         uClibc
[faye@localhost uClinux-dist-test]$ make linux_hwselect SYSPTF=nios_605.ptf KCONFIG_NOTIMESTAMP=1 make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-  ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x hwselect
  RUNNING hwselect
--- Please select which CPU you wish to build the kernel against:
(1) cpu_0 - Class: altera_nios2 Type: f Version: 5.11
Selection: 1
--- Please select a device to upload the kernel to:
(1) cfi_flash_0
        Class: altera_avalon_cfi_flash
Selection: 1
--- Please select a device to execute kernel from:
(1) sram_0
        Class: user_logic_SRAM_16Bits_512K
(2) sdram_0
        Class: altera_avalon_new_sdram_controller
(3) epcs_controller
        Class: altera_avalon_epcs_flash_controller
Selection: 2
--- Summary using
PTF: nios_605.ptf
CPU:                            cpu_0
Device to upload to:            cfi_flash_0
Program memory to execute from: sdram_0
--- Settings written to /home/faye/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/hardware.mk
[faye@localhost uClinux-dist-test]$[/b]
--- Quote End ---
Thx !
Hi
I can run cpu freq up to 100Mhz on uClinux OS,and feel speed up to run algorithm program.
1.Make zImage in linux-2.6.16.1 dir
--- Quote Start ---
# cat cpuinfo
CPU:            NIOS2
MMU:            none
FPU:            none
Clocking:      100.0MHz
BogoMips:      49.56
Calibration:    24780800 loops# free
              total        used        free      shared      buffers
  Mem:        7012        5292        1720            0            0# [/b]
--- Quote End ---
2.Make zImage in uClinux-dist-testdir (but i must add path ~/uClinux-dist-test to open my new ptf file).
--- Quote Start ---
/> cd /proc
/proc> cat cpuinfo
CPU:            NIOS2
MMU:            none
FPU:            none
Clocking:      100.0MHz
BogoMips:      49.56
/proc> free
MemTotal:        6548 kB
MemFree:          4844 kB
Buffers:            0 kB
/proc>[/b]
--- Quote End ---
