Running from on-chip memory.
I have been trying for several days to get a custom board to run Nios II embedded processor with a hello world program with no luck. I have successfully achieved this task with evaluation kits, but so far not with my board. I have searched this forum and tried several things that I saw, but I had no luck.
My board is about as simple as they come. A Cyclone, EPCS4, and oscillator with both an active serial programming header and JTAG header (pulled directly from the Altera manual). I have used the FPGA for other tasks (so the board works), but I have only just started trying the Nios processor.
My current SOPC configuration is:
- Nios II/s with debug level 1 running at 50Mhz.
- UART
- JTAG UART
- On-chip Memory configured as ROM
- On-chip Memory configured as RAM
- EPCS Controller
In the FPGA configuration, I have a PLL taking 25Mhz and upping it to 50Mhz for the clk line of the processor. I have all the pin assignments set to output pins with the exception of the reset_n line which is set as an input pin normally vcc.
In the Nios IDE (v5.1), I have setup a "hello world small" program. The system library is set to output stdin/out/err to the jtag uart and the rom gets the text and the read-only info, while the ram gets the read-write/heap/stack info.
I program the FPGA configuration and then perform a "run as hardware" in the IDE and everything goes with no errors. I am expecting to see the hello world output in the terminal, but I don't. Sometimes I get a series of ascii characters like the baud rate is wrong, other times I get nothing. I have tried changing my clock speed with no luck.
I tried to add some serial uart code from a previous (known good) program to see if it was just bad JTAG communication. It seems that the program is not running at all. No serial activity at any baud rate...
I do see the rom and ram *.hex files being created. I have tried to recompile the FPGA configuration and re-program the FPGA but the program doesn't run. How can I verify that the new *.hex files were included in the configuration?
I have tried:
- changing the clock input speed (lower and higher than 50Mhz)
- various memory configurations (started with a single on-chip memory)
- various hello-world programs (stand alone, small, normal, etc)
- to get debug info going through the UART
- looked at the clock input on an external IO and it is there
- to change the reset address to the EPCS
- and more.
I must be missing something simple.
Can anyone give me any ideas? I am running out of hair to pull out!
Chris Lathan
We were just having the same issue and found that the program was hanging in alt_main because of problems initializing the flash.
Click Run/Debug... Click the Debugger tab, and on the right hand side you can tell the debugger to break at alt_main. This lets you see how the initialization progresses. I suggest stepping into alt_sys_init() to see which individual init functions run successfully.
This should help narrow the problem down. For me, the program hung when initializing the flash. Just to get up and running, I commented the line initializing the flash in the Altera-generated code. After that, all systems were go.
Good luck!
Dave
I am working toward a solution. I haven't completely defined the problem I was having, but I was able to get the program to run.
It turns out that I had a mistake in my SOPC configuration. The on-chip memory I allocated was too large but I never got any error from the fitter in Quartus.
Something I did made the error appear. This gave me something to chase and fix. I finally found the memory size that would fit and run the program and everything ran fine from there.
The only change I made was an order of operation change. I was running from SOPC-Quartus-IDE but when I changed to SOPC-IDE-Quartus, the error appeared.
I had compiled the FPGA configuration probably 30 times with no sign of an error. Of course I can't repeat it now. I change my order of operation back to SOPC-Quartus-IDE and all is fine.
I guess I was just too dependent on being told something was wrong...
Thanks for the help.
Chris
1) Make sure the program fits into the ROM files
2) Once the ROM files have been written, you have to recompile and reprogram the PLD from Quartus.
