12619 Discussions
Cannot write on-chip memory with fread.
I use DE2-70 to develop my project. My uClinux is running in SDRAM, and I want to copy a file to on-chip memory, but there is only 0 in on-chip memory, the fread() function didn't work.
can anyone help me in removing this error,
Thanks a lot !
Code:
int main()
FILE *fp1;
unsigned int *mem_source = (unsigned int *)(na_onchip_mem_source|0x80000000);
fp1 = open_file("P.dat",READ);
long length;
fseek(fp1, 0L, SEEK_END);
length = ftell(fp1);
int counter = 0;
fseek(fp1,0L,SEEK_SET);
fread(mem_source,length,1,fp1);
int i;
for(i=0;i<(length+3)/4;i++)
printf("mem_source %d = %x\n",i,mem_source[i]);
return 0;
You cannot use onchip_mem directly. Please read to a buffer, (dump/check it) then copy the content to the onchip_mem.
You should check return of every file functions, such as open/seek/read/close etc.
- Hippo
I want to use DMA to encrypt file between two onchip mems, and it will save some time if I can read data to onchip mem directly. Is there any other method can do that?
Any of your help will be appreciated!
You cannot handle interrupt in user space. So you might have to do it in kernel space, like using a driver or syscall.
Beside, you should add return value check in your program and test it again before doing anything else.
- Hippo
--- Quote Start ---
--- Quote End ---
This _should_ be possible in a Kernel driver ?!?!?!?
-Michael
But I can use fwrite() to move data from on-chip mem to a file directly.
Why fread() can't copy a file to on-chip mem?
I tried kernel function like read(), failed too.
Hi
I wonder if the fread did work eventually to write to on chip memory? if so, what was the solution?
thanks
