Class and C++
Hi everyone,
I'm brand new developer with NiosII and C++, and I'm experiencing some problems with NiosII IDE, expecially in building application in C++.
I created a classe called "thread". I wrote 2 files, an simple header file thread.h and a cpp file, thread.cpp.
During building, I receive this error message:
Compiling thread.cpp...
../thread.cpp:10: error: new types may not be defined in a return type
../thread.cpp:10: error: return type specification for constructor invalid
../thread.cpp: In member function `void thread::begin()':
../thread.cpp:16: error: `TIMER_BASE' undeclared (first use this function)
../thread.cpp:16: error: (Each undeclared identifier is reported only once for each function it appears in.)
../thread.cpp:16: error: expected primary-expression before ')' token
../thread.cpp: In member function `void thread::end()':
../thread.cpp:26: error: `TIMER_BASE' undeclared (first use this function)
make: *** [obj/thread.o] Error 1
code listed below: thread.h
# ifndef _THREAD_H_# define _THREAD_H_
# define TIMEOUT# define TIME# include "altera_avalon_timer_regs.h"
class thread
public:
int state;
int ticks;
thread();
~thread();
void begin();
void end();
int getState();
# endif //_THREAD_H_
code listed below: thread.cpp
# include <system.h>
# include "thread.h"# include "altera_avalon_timer_regs.h"
void thread::thread() {}
void thread::~thread() {}
void thread::begin(void)
// inizializzazione timer e partenza
IOWR_ALTERA_AVALON_TIMER_PERIODL(TIMER_BASE, TIME);
IOWR_ALTERA_AVALON_TIMER_PERIODH(TIMER_BASE, 0x00);
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_BASE, 0x07);
state = 1;
ticks = 0;
void thread::end(void)
// terminazione timer
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_BASE, 0x0b);
state = 0;
int thread::getState(void)
return state;
So, I don&#39;t understand where are the problems:
1. What does it mean "new types may not be defined in a return type"?
2. Why TIMER_BASE is unknown, although is defined in <system.h> header file?
Someone can help me? Thanks.
G.
--- Quote Start ---
originally posted by g.sanzi@Mar 28 2006, 10:03 AM
hi everyone,
i&#39;m brand new developer with niosii and c++, and i&#39;m experiencing some problems with niosii ide, expecially in building application in c++.
i created a classe called "thread". i wrote 2 files, an simple header file thread.h and a cpp file, thread.cpp.
during building, i receive this error message:
compiling thread.cpp...
../thread.cpp: in member function `void thread::begin()&#39;:
../thread.cpp:16: error: `timer_base&#39; undeclared (first use this function)
../thread.cpp:16: error: (each undeclared identifier is reported only once for each function it appears in.)
../thread.cpp:16: error: expected primary-expression before &#39;)&#39; token
../thread.cpp: in member function `void thread::end()&#39;:
../thread.cpp:26: error: `timer_base&#39; undeclared (first use this function)
make: *** [obj/thread.o] error 1
Code listed below: thread.h[/b]
class thread
public:
  int state;
  int ticks;
  thread();
  ~thread();
  void begin();
  void end();
  int getState();
state = 1;
ticks = 0;
state = 0;
return state;
G.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13853)
--- Quote End ---
[/b]
--- Quote End ---
i solved myself: it&#39;s only for a fucked ";" after class declaration!!!!!!!
hello,
I cannot define a class using Nios II IDE environment! the class is defined in basicOCR.h as follow:
--- Quote Start ---
class basicOCR{
public:
float classify(IplImage* img,int showResult);
basicOCR ();
void test();
private:
char file_path[255];
int train_samples;
int classes;
CvMat* trainData;
CvMat* trainClasses;
int size;
static const int K=10;
CvKNearest *knn;
void getData();
void train();
--- Quote End ---
Although "Support C++" is activated, errors occur:
--- Quote Start ---
../basicOCR.h: At top level:
../basicOCR.h:25: error: syntax error before "basicOCR"
../basicOCR.h:25: error: syntax error before '{' token
../basicOCR.h:30: error: syntax error before ':' token
--- Quote End ---
any ideas ? thanks
Is your .h file included from a .c file or a .cpp? I think it needs to be .cpp so that Eclipse compiles it in C++ mode.
Actually it did (basicOCR.cpp)
Hmmm I don't think that you need to rename the header files to .hpp to make the compiler stay in C++ mode.
The include statement isn't inside an extern "C" {} block by any chance?
renaming the header files came out with nothing!
the basicOCR.cpp includes the header file as (#include "basicOCR.hpp"), but does this have to do with the header file itself?
I'm sorry if I couldn't get your last reply!
Be sure the class declaration in the header file ends with a ;, like:
class abc { //..... }; Bill
