Code Coverage
Does anyone know if there is a code coverage tool for the NIOS2? What I am talking about is a tool that connects to the hardware and traces each if, while, for, switch, etc. It dumps a report/analysis that lets you know where your dead code is. It sounds complicated, but in all actuality it takes your source code, inserts a data bus write (tag) at each conditional statement, and then recompiles it. Yes it does increase the app size and slows you down a bit, but it does what it's supposed to do - code coverage. All you need is to supply a nWE and 32 bits of data. When you run your code, it collects the data tags and writes a report for you. It's kind of like a device specific logic analyzer. We use Metrowerks Codetest, but they don't have NIOS2 support at this time. Just wondering if anyone else has something similar.
You might check out the Lauterbach tools, which now support Nios II: http://www.lauterbach.com (http://www.lauterbach.com) I have heard that they have this capability, although I haven't used it myself.
