Compact Flash Card
Hi ecos community,
I have a Nios dev board (Stratix edition) running an eCos application that logs data onto a Compact Flash card.
My application runs well, but I am trying to improve it in the way it deals with the Compact Flash card.
I would like my application to be able to get info on the CF card, ie card size, card maker, free space etc. I suspect the CF driver does not support this at present, but if it does I would like to know how.
Also, the CF driver supports interrupt driven card insertion functionality for card initialization, but on my board this does not work, as far as I can tell no interrupt is generated when a card is inserted. If anyone has experience in this area I would like to hear about it.
More detail follows...
From the API the following code should allow access to CF info:
error = cyg_io_lookup("/dev/cfa/1",&cf_handle); // get handle to CF
error = cyg_io_get_config(&cf_handle,0,xbuf,&len);
but the function alt_avalon_cf_get_config in altera_avalon_cf.c is just an empty stub, however the line of execution never appears to reach this code.
Is there anyone else out there using CF cards?
Peter
There was a mistake in the second line of code, the correct code is below:
error = cyg_io_get_config(cf_handle,0,xbuf,&len); // call for info, if any
The following code fragments are a first attempt at providing access to CF information. The alt_avalon_cf_get_config stub is filled out and eCos cleaned and rebuilt.
// fill out stub in altera_avalon_cf.c
// Altera Avalon compact flash driver
alt_avalon_cf_get_config(disk_channel *chan,
cyg_uint32 key,
const void *xbuf, //cyg_disk_info_t;
cyg_uint32 *len)
cyg_disk_info_t *info = chan->info; // info is a pointer
cyg_disk_info_t *buf = (cyg_disk_info_t *) xbuf;
cyg_disk_identify_t *ident = &chan->info->ident;
Cyg_ErrNo res = ENOERR;
D("alt_avalon_cf_get_config\n");
if (!chan->init)
return -EINVAL;
if (*len < sizeof(cyg_disk_info_t))
return -EINVAL;
*buf = *info;
*len = sizeof(cyg_disk_info_t);
//D((" serial = &#39;%s&#39;\n", ident->serial));
//D((" firmware rev = &#39;%s&#39;\n", ident->firmware_rev));
D(" model num = &#39;%s&#39;\n", ident->model_num);
D(" block_size = %d\n", info->block_size);
D(" blocks_num = %d\n", info->blocks_num);
return res;
Here is a code fragment to access the info. In this case
the block size, number of blocks and CF model string.
// code to access CF info
// use API call &#39;cyg_io_get_config&#39;
// information on the CF card
cyg_disk_info_t cf_info;
char cf_model[20];
// later on...
{ // get CF card info
cyg_io_handle_t cf_handle;
void *xbuf = (void *)&cf_info; //cyg_disk_info_t
Cyg_ErrNo error;
cyg_uint32 len = sizeof(cyg_disk_info_t);
error = cyg_io_lookup("/dev/cfa/1", &cf_handle);
if(error!=0) printf("lookup error:%i\n",error);
else
printf("cf get_config error: %i %i\n",error,-EINVAL); // should get -EINVAL
//cf_info_ptr = *(cyg_disk_info_t *)xbuf;
// get useful info
block_size = cf_info.block_size;
blocks_num = cf_info.blocks_num;
strncpy(cf_model,cf_info.ident.model_num,16);
printf("block size:%i num_blocks:%i %s\n"
,cf_info.block_size,cf_info.blocks_num,cf_model);
Looks like I get to answer my own questions.
