Compiler
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif
movia at,((90057600)/115200)
28: 00400034 movhi at,0
2c: 0840c354 ori at,at,781
movia at,((90000000+57600)/115200)
30: 00415774 movhi at,1373
34: 0852a014 ori at,at,19072
I just tried assembling the following code:
       .set noat        movia at,((90000000+57600)/115200)
with the command line:
nios2-elf-gcc -c -o test.o test.s nios2-elf-objdump -S test.o
And got a pair of instructions which load up the value 781 (decimal).
Which version of the tools are you using?
Test code as following:# ====================================
.set noat
_start:
.end# ====================================
I got these result:
[NIOS2 GNU Shell]$ nios2-elf-gcc -c -o test.o test.S
[NIOS2 GNU Shell]$ nios2-elf-objdump -S test.o
test.o: file format elf32-littlenios2
Disassembly of section .text:
00000000 <_start>:
[NIOS2 GNU Shell]$
Why?
but , got the result with these cmd line:
[NIOS2 GNU Shell]$ nios2-elf-as -o test.o test.S
00000000 <_start>:
0: 00400034 movhi at,0
4: 0840c344 addi at,at,781
c: 0840c344 addi at,at,781
/cygdrive/g/nios2/src/boot_loader
[NIOS2 GNU Shell]$
--- Quote Start ---
originally posted by simon.embed@Mar 16 2005, 10:01 AM
test code as following:# ====================================
.set noat
_start:
i got these result:
[nios2 gnu shell]$ nios2-elf-gcc -c -o test.o test.s
[nios2 gnu shell]$ nios2-elf-objdump -s test.o
disassembly of section .text:
00000000 <_start>:
[nios2 gnu shell]$
why?
--- Quote End ---
What version are you running? If you type nios2-elf-gcc -v this will tell you.
Using your file
.set noat
_start:
.end
With the command lines below I get exactly what you&#39;d expect
[SOPC Builder]$ nios2-elf-gcc -c -o test.o test.S
/cygdrive/d
[SOPC Builder]$ nios2-elf-objdump -S test.o
00000000 <_start>:
Thanks, rugbybloke. I got it. I have included some head file(#include "macros.h") in source file, which get wrong. Instruction MOVIA was redefined in that head file!
maybe the compiler bug for the following test code:# test.S# define ALT_CPU_FREQ 90000000# define BAUD_RATE 2400 //1200# define C_DIVISOR ((ALT_CPU_FREQ+BAUD_RATE/2)/BAUD_RATE)
.equ A_DIVISOR , ((ALT_CPU_FREQ+BAUD_RATE/2)/BAUD_RATE)
.macro MOVUIK32 _reg,_val
.if (\_val >>16) == 0
MOVUI \_reg,%lo(\_val)
.elseif (\_val <<16) == 0
MOVHI \_reg,%hi(\_val)
.else
MOVIA \_reg,\_val
.endif
.endm
.section .text
.align 2
.set noat
_start:
MOVUIK32 r2,C_DIVISOR
MOVUIK32 r3,A_DIVISOR
.end
You may change the valu of ALT_CPU_FREQ and BAUD_RATE macros, and then check the compiling result!
