12620 Discussions
Compiling Error when adding ethernet into kernel
I am going to develop ethernet applications with Nios2 and uClinux on CYCLONE_EVAL_1C12. After adding the ethernet module according to NIOSWIKI, the kernel compiling failed.
Could anybody do me a favor to figure it out? Thank you very much.
The following is my work flow :
HOST COMPUTER: openSUSE linux
BOARD: niosII_cyclone_eval_1c12/verilog/standard/standard_1c12.ptf (I use altera's example directly)
# set target ptf (if not, the customization of kernerl would fail. so I performed this step)
make vendor_hwselect SYSPTF=~/uClinux-dist/standard_1c12.ptf
# configure linux kernel
make menuconfig # I set all others according to NIOSWIKI except the ethernet driver where I
# chose MORETHANIP_10M_100M
# set target ptf again
# make kernel and applications
make romfs # error, ignored according to NIOSWIKI
make # error, ignored according to NIOSWIKI
make# there are still lots errors as the following:
arch/nios2nommu/kernel/setup.c: In function `setup_arch':
arch/nios2nommu/kernel/setup.c:230: error: `na_mtip_mac_control_port' undeclared (first use in this function)
arch/nios2nommu/kernel/setup.c:230: error: (Each undeclared identifier is reported only once
arch/nios2nommu/kernel/setup.c:230: error: for each function it appears in.)
arch/nios2nommu/kernel/setup.c:325: warning: implicit declaration of function `paging_init'
make[2]: *** [arch/nios2nommu/kernel/setup.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CC arch/nios2nommu/mm/memory.o
CC arch/nios2nommu/mm/dma-noncoherent.o
make[1]: *** [arch/nios2nommu/kernel] Error 2
make[1]: *** Waiting for unfinished jobs....
LD arch/nios2nommu/mm/built-in.o
make[1]: Leaving directory `/home/yongping/uClinux-dist/linux-2.6.x'
make: *** [linux] Error 1
It seems that some header file is missed. I am not familiar with linux system.
Thank you.
Please check your mtip port address defs in linux-2.6.x/include/nios2_system.h .
try modify the define of na_mtip_mac_control_port in setup.c.
you may need to check drivers/net/Space.c and mtip1000.c.
I have never tested these drivers. Please forward the patches to the wiki when you work through.
It is nice to see your joint.
Cheer.
Hippo
