Configure kernel failed
I have installed the Linux PlugIn for the Nios II IDE and try to build a kernel as described in the "Quick Start Guide.pdf". 'Configure kernel' step doesn't work properly. DOS window flashes with following message and disappears quickly.
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
make: Entering directory `/cygdrive/d/altera/kits/nios2_60/bin/eclipse/plugins/c
om.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
no emulation specific options.
HOSTCC scripts/basic/fixdep
gcc: not found
make[2]: *** [scripts/basic/fixdep] Error 127
make[1]: *** [scripts_basic] Error 2
make: *** [menuconfig] Error 2
make: Leaving directory `/cygdrive/d/altera/kits/nios2_60/bin/eclipse/plugins/co
My computer is running Windows NT. I am able to compile Hello_World supplied along with the distribution in /examples/software folder. I am using Quartus 5.0, Nios 5.0 and nios2linux 1.4.
It looks like for compilation, hello_world uses 'nios2-elf-gcc' from altera\kits\nios2_60\bin\nios2-gnutools\H-i686-pc-cygwin\bin
but during 'Configure kernel' this path is missing (not being set some where) , hence it is unable to find 'gcc'. But this is a guess only and still I don't have any clue for "no emulation specific options." statement.
Please help me out
