I have installed the Linux PlugIn for the Nios II IDE and try to build a kernel as described in the "Quick Start Guide.pdf". 'Configure kernel' step doesn't work properly. DOS window flashes with following message and disappears quickly. ------------------------------------------------ Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ make: Entering directory `/cygdrive/d/altera/kits/nios2_60/bin/eclipse/plugins/c om.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' no emulation specific options. HOSTCC scripts/basic/fixdep gcc: not found make[2]: *** [scripts/basic/fixdep] Error 127 make[1]: *** [scripts_basic] Error 2 make: *** [menuconfig] Error 2 make: Leaving directory `/cygdrive/d/altera/kits/nios2_60/bin/eclipse/plugins/co m.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' My computer is running Windows NT. It seems like the installer hasn't installed a native i86 version of gcc, though I am not vety sure. Please help me outLink Copied
