12745 Discussions
Constraints file for D10-Lite Computer_System from Intel FPGA University Program
kodachi77
I've downloaded version 21.1 of Intel FPGA University Program and started to experiment with NIOS II computer system for DE10-Lite. When I try to perform full compilation the design fails timing analysis. Setup time slack for system clock is -931ns and for ADC clock -12ns.
SDC file looks like a vanilla file from any Altera design.
create_clock -period "50.0 MHz" [get_ports CLOCK_50]
create_clock -period "50.0 MHz" [get_ports CLOCK2_50]
create_clock -period "10.0 MHz" [get_ports CLOCK_ADC_10]
create_clock -period "100.0 MHz" [get_ports DRAM_CLK]
derive_pll_clocks
derive_clock_uncertainty
Would it possible to share detailed file that allows to achieve timing closure for this design? This will be really helpful since it is hard to come by fully specified constraint files for DE boards.
Main areas of interest: IO input/output delays, multicycle and false paths.
Thank you!
ShengN_Intel
DE10-Lite_Computer is a general design example for the manual DE10-Lite_Computer_NiosII.pdf.
You may refer to DE10-Standard_Computer design example for more completed sdc constraints file.
Sheng
ShengN_Intel
Can share the link where you download the design?
Sheng
kodachi77
The design is a part of the Monitor Program install that can be found here: https://fpgacademy.org/tools.html
After installation it can be found in the following directory:
.../intelFPGA_lite/21.1/University_Program/Computer_Systems/DE10-Lite/DE10-Lite_Computer
ShengN_Intel
Sheng
kodachi77
