Cyclone SL811HS interrupts
I think there's a problem with the Cyclone Development Board.
I am using the NIOS-II Kitchen sink design, and I have coded a small USB driver for the board. I am now capable of performing a full enumeration sequence on Windows XP.
However - I am unable to get interrupts from the SL811HS controller into the NIOS-II core. So the way I've implemented the "driver" is by having a loop continuously polling the SL811HS's interrupt status register. The sample code which was presented in this forum, uses the same technique.
On the NIOS-1 examples, some sort of interrupt is used. I beleive it may run on a timer-interrupt instead of the "real" interrupt from the SL811HS - Is this correct?
If there is an issue with the USB controller and Interrupts, please let me know.
The interface component we created to connect the SL811HS to the Avalon bus has an extra facility for enabling/diabling interrupts. The bit to allow interrupts to pass through lives in the 3rd register of our interface component (usb_base_address+8) at bit 2. Writing a 0x4 to this register will enable interrupts from the SL811HS to reach the Nios processor.
I am emailing you the most recent version of our document describing our USB reference project (a similar document should have come on the CD with your board). It contains a description of our SL811HS-to-Avalon interface.
Dennis Scott
Microtronix Datacom Ltd.
Wow.. again.. brilliant support - thanks guys.
Yes - it did work, I am now getting interrupts - I don't know if I missed something in the docs.
To anyone following this discussion here's how I enabled interrupts from the SL811HS to the NIOS-II core..
// you need this:
volatile unsigned int *pAddrSel = (unsigned int*) (USB_BASE);
// write a single byte to the controller at addr
void Write ( unsigned int addr, unsigned int value )
pAddrSel[0] = addr;
pAddrSel[1] = value;
then somewhere in your code...
// enable the interrupts to come through
IOWR_ALTERA_AVALON_PIO_DATA(USB_BASE + 8, 0x04);
// register an interrupt handler for the USB interrupts
alt_irq_register (USB_IRQ, NULL, handle_USB_interrupts);
// enable all interrupts from the controller
Write ( REG_INTERRUPT_ENABLE, 0x7f );
that's it...
