12652 Discussions
Cyclone V LCD / I2C (baremetal) sample for Altera's SoC DevKit
Hi community,
anybody out there ever programmed the Newhaven LCD on the Altera SoC (Cyclone V) DevKit baremetal
If I didn't miss something Altera's hwlib doesn't provide support for I2C (not to mention support for the LCD).
As I'm not a linux expert the linux i2c driver isn't very helpfull either.
If someone could give me a hint where to look for a starting point, that would be really great.
Thanks a lot for your support!
I want to give you some hints to get it running.
it's not very difficult to get it running on a baremetal system. You can still use the hwlib.
There is a headerfile called alt_i2c.h. This file contains a lot of definitions, needed to implement an i2c driver for your application.
To write something to the LCD you have to do the following steps:
first step: you need to write an init-function for the i2c interface. here you have to do the following steps:
  1. Disable the i2c controller by clearing the enabled bit in the alt_i2c_en register
  2. set the controller to master mode (register alt_i2c_con_mst_mod
  3. set the speed to standard (the newheaven display only supports 100khz clock rate) (register alt_i2c_con_speed
  4. enable the i2c controller (set enabled bit in the alt_i2c_en register)
second step: address the slave
  1. write the address of the slave to the alt_i2c_tar register
third step: the write function:
  1. to send data you have to set the ALT_i2c_data_cmd_cmd Register to WRITE
  2. write the data to the alt_i2c_data_cmd_dat Register
Now data will be send on the I2C. If you want to implement a full driver you can also check the status register etc. when you send some data...
Some hints for the newheaven LCD:
  • Slave address is 0x28 (and not 0x50)
  • between the commands you send, you need a delay (normally 100µs).
  • A full list of special commands for the display you can find in the newheaven specification. (Download it from the newheaven website. The LCD is the NHD-0216K3Z)
I hope it helps you a bit.
Regards!
