DE1 Flash access problems
Hello forum,
I'm a beginner with NIOS II. I've successfully tested RS232 communication using the uart component in SOPC, however I'm having a hard time with the CFI flash.
This is my configuration:
SOPC block diagram: http://i52.tinypic.com/2znyc77.png
flash configurations: http://i53.tinypic.com/314auyh.png
pin planner: http://i53.tinypic.com/4hqbyg.png
alt_pll is shifting the SDRAM and Flash clock by -6ns. SDRAM works fine though, unlike the flash.
I've tried a different phase shifts for the flash's clock but I fail to nail the right one, maybe. If a phase shift is even needed... I've no idea!
I'm using the following C code (from Nios II Software Developer’s Handbook page 160):
# include <stdio.h># include <string.h># include "sys/alt_flash.h"# define BUF_SIZE 1024 int main() { alt_flash_fd* fd; int ret_code; char source; char dest; /* Initialize the source buffer to all 0xAA */ memset(source, 0xAA, BUF_SIZE); fd = alt_flash_open_dev("/dev/cfi_flash_0"); if (fd != NULL) { ret_code = alt_write_flash(fd, 0, source, BUF_SIZE); if (ret_code == 0) { ret_code = alt_read_flash(fd, 0, dest, BUF_SIZE); if (ret_code == 0) { /* * Success. * At this point, the flash is all 0xAA and we * have read that all back to dest */ } } alt_flash_close_dev(fd); } else { printf("Cannot open flash device\n"); } return 0; } It seems that fd == NULL for some reason. I hope you can provide an explanation... :(
I'm sure the problem is somewhere in my HW settings (timing most likely, could be pins too though). I just can't nail the right configuration.
