I am doing the tutorial creating hello_world for a nios Development Board (niosII Sftw. Developers Handbook - Chap3 Getting started from de command line) Tools 9.1 : nios II EDS -> command shell Board : Kit DE2 - EP2C35F672C6N ( Swith RUN position) Connection : USB- Blaster I have do the tutorial with the nios2 commands tutorial on ../nios2eds/examples/verilog/nikosII_cycloneII-2c35/standard/software_examples/app/hello_world open first command-shell ./create-this-app nios2-configure-sof open second command-shell nios2-terminal -> DE2 Load blue led on When i download and run hello_world.elf on nios2 sopc nios2-download -g hello_world.elf The stream Hello World dont transmitted to terminal and THE ERROR MESSAGE IS Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused I have a node jtag debug and jtag-UART $jtagconfig -n 1) USB-Blaster [USB-0] 020B40DD EP2C35 Node 19104600 Node 0C006E00 -I have on forum that there is not problem with version > 7.1 THANKS IN ADVANCE链接已复制
0 回复数
