DHCPD
Can somone help me ?
To make a DHCPD server on the nios board?
configure busybox to include the dhcpd server applet.
There is no DHCPD server inside busybox. I found this?
http://udhcp.busybox.net/ (http://udhcp.busybox.net/
How can i compile a applet inside busybox then?
Help !
Open up a nios II SDK Shell:
cd $LINUX_NE_ROOT
cd busybox
make menuconfig
And don't forget to take a peek inside the reference guide for more info about busybox.
hello!
I start to work on stratix II with my school. First I have created and upload a kernel and a fs. Then I have logged on the board with sdkshell. Up to now, it's OK.
Now,I want to make a DHCPD server on the nios board so i did what ken said, but i didn't know what I have to do after?
I have the same problem. I want to make a dhcp server on a stratixII board with uClinux. I change the path to my kernel build and check options that I need like said ken. But I don't know what to do after.
More over I haven't dhcpd.conf in /etc and no dhcpd deamon.
Thanks for help
Bye
Hello
After that, I did :
-make install
-upload the kernel, the file system and the NIOSII_processor on the board
The problem appeared when using "nio2-terminal" command:
init started: BusyBox v1.00-pre8 (2006.02.08-15:50+0000) multi-call binary
Bad inittab entry: ttyJ0:vt100:/bin/agetty 115200 ttyJ0
No more tasks for init -- sleeping forever.
If anyone has an idea?
