12745 Discussions
DMA problem on alt_dma_txchan_send
Hi every body.
I have a problem with the NIOS DMA setting.
In my system, I need to read data from a device by a MM-Avalon interface, and write the data in a other device with the MM-Avalon interface. The memoryes in the devices are FIFO. The part of my code about DMA is:
# include "system.h"
# include <io.h>
# include <stdio.h>
# include <sys/alt_irq.h>
int rc;
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
void* tx_data = (void*) (MC_BASE+MC_READ);
void* rx_buffer = (void*) (GIGAINT_BASE);
if ((txchan = alt_dma_txchan_open(DMA_0_NAME)) == null
ret++;
alt_dma_txchan_reg (*pTxchan);
if(alt_dma_txchan_ioctl(txchan,ALT_DMA_SET_MODE_32,null)<0)
printf ("Failed to set ALT_DMA_SET_MODE_32 in TX\r\n");
if(alt_dma_txchan_ioctl(txchan,ALT_DMA_RX_ONLY_OFF,tx_data)<0)
printf ("Failed to set ALT_DMA_RX_ONLY_OFF in TX \r\n");
if(alt_dma_txchan_ioctl(txchan,ALT_DMA_TX_ONLY_ON,tx_data)<0)
printf ("Failed to set ALT_DMA_TX_ONLY_ON in TX \r\n");
if ((rxchan = alt_dma_rxchan_open(DMA_0_NAME)) == null
ret++;
if(alt_dma_rxchan_ioctl(rxchan,ALT_DMA_SET_MODE_32,null))
printf ("Failed to set ALT_DMA_SET_MODE_32 in RX\r\n");
if(alt_dma_rxchan_ioctl(rxchan,ALT_DMA_TX_ONLY_OFF,rx_buffer))
printf ("Failed to set ALT_DMA_TX_ONLY_OFF in RX \r\n");
if(alt_dma_rxchan_ioctl(rxchan,ALT_DMA_RX_ONLY_ON,rx_buffer))
printf ("Failed to set ALT_DMA_RX_ONLY_ON in RX \r\n");
rc = alt_dma_txchan_send ( txchan,tx_data,length,null,null);
if (rc < 0)
printf ("Failed to post transmit request, reason = %i\r\n", rc);
rc = alt_dma_rxchan_prepare (rxchan,rx_buffer,length,done,null);
if (rc < 0)
printf ("Failed to post read request, reason = %i\r\n", rc);
while (!rx_done);
"done" is the function to call when the DMA end.
"length" is 256, and teh DMA dimension is 1024
The problem is the function < alt_dma_txchan_send > return -22, but i don't understand where is the bug.
Help me!!!
Thank you
I had the same issue.
In my case I had accidentally kept the width of DMA length register as 4 bits, resulting in the -22 error you described. To solve this, I adjusted the width of the DMA length register to 13 bits (default setting). This is good enough for most transfers.
