12746 Discussions
DMA ----send data from uart to SDRAM
I Have a program about DMA , isend data from RS232 to SDRAM, SDRAM can receive data ,bur when i check this data whther rightly, i find in't not the data that send from uart . the problem is i can't receive right data from uart. this problem have trouble me about 3 weeks .please give me a sugesttion and verify this programs. deeply thanks.
( Another program work rightly to send data from SDRAM to RS232 ,so SDRAM and RS232 work rightly)
PLEASE HELP ME,THANK YOU
the program is:
//&#23383;&#31526;&#20018;&#20889;&#21040;SDRAM,&#20877;&#20174;SDRAM&#35835;&#21040;RS232# include <stdio.h># include <stdlib.h># include "sys/alt_dma.h"# include "altera_avalon_uart_regs.h"# include "system.h"# include "alt_types.h"# include <string.h>
static volatile int tx_done = 0;
volatile static char str[] = {"this is sdram data&#65292;written by memcpy function\n"} ;//&#24453;&#20889;&#21040;SDRAM&#30340;&#25968;&#25454;# define TRANSFER_LENGTH 1024
//&#22238;&#35843;&#20989;&#25968;
static void done (void* handle)
tx_done++;
int main()
alt_u8 i;
FILE *fp_LCD=0;
FILE *fp_RS232=0;
fp_LCD = fopen("/dev/lcd","w");
fp_RS232 = fopen("/dev/rs232","w");
int rc;
alt_dma_txchan txchan;
void* source = (void*)(SDRAM_BASE);/* &#28304;&#22320;&#22336; */
void* dest = (void*)IOADDR_ALTERA_AVALON_UART_TXDATA(RS232_BASE);
//memset(SDRAM_BASE,'aaaaaaaaaaaaaaaa',TRANSFER_LENGTH);
memcpy(SDRAM_BASE,str,strlen(str)); //&#23558;STR&#22320;&#22336;&#20013;&#30340;&#23383;&#31526;&#20018;&#20889;&#21040;SDRAM
/* &#25171;&#24320;&#21457;&#36865;&#36890;&#36947; */
if ((txchan = alt_dma_txchan_open("/dev/dma")) == 0)
{ printf ("successful to open transmit channel\n");
exit (1);
/* &#35774;&#32622;&#30446;&#26631;&#22320;&#22336;&#22266;&#23450; */
if ((rc = alt_dma_txchan_ioctl(txchan, ALT_DMA_TX_ONLY_ON, dest)) < 0)
{ printf ("Failed to set ioctl, reason = %i\n", rc);
exit (1);
//&#35774;&#32622;&#27599;&#27425;&#21457;&#36865;&#19968;&#20010;&#23383;&#33410;&#65292;&#21363;8&#20301;&#65292;&#22240;&#20026;UART&#27599;&#27425;&#21482;&#21457;&#36865;8&#20301;
if((rc = alt_dma_txchan_ioctl(txchan,ALT_DMA_SET_MODE_8 ,NULL))<0)
{ printf("Failed to set mode 8\n");
exit(1);
/* &#24320;&#22987;&#21457;&#36865; */
if ((rc = alt_dma_txchan_send(txchan, source, strlen(str), done, NULL)) < 0)
{ printf ("Failed to post transmit request, reason = %i\n", rc);
exit (1);
/* &#31561;&#24453;&#21457;&#36865;&#32467;&#26463; */
while (!tx_done);
printf ("Transfer to jtag!\n");
fprintf(fp_LCD,"Transfer to lcd! \n");
fprintf(fp_RS232,"Transfer to rs232 ! \n");
for(i=0;i<=strlen(str);i++)
printf ("%s\n",(SDRAM_BASE+i));
fprintf(fp_LCD,(SDRAM_BASE+i));
//fprintf(fp_RS232,SDRAM_BASE);
return 0;
SORRY, the software visions :
quartus 10.0+NIOS 10.0
I need sdram to uart ,trying for 2 weeks but could not make it work.
will you share for me.I will be thankful to u.
it seems you need rx channel instead of tx channel.see embedded guide.
