DMA to UART
I have downside program in order to realize transfer block data from onchip_memory to UART by DMA, however it doesn't work. The message shows the transter has completed, but there is no data transfered to UART.
I don't know is there some problem with my program or system set?
--- Quote Start ---
#include <stdio.h># include <stddef.h># include <stdlib.h># include "sys/alt_dma.h"# include "alt_types.h"# include <system.h>
/* flag used to indicate the transaction is complete */
volatile int dma_complete = 0;
/* function that is called when the transaction completes */
void dma_done (void* handle)
dma_complete = 1;
int main (void)
char buffer[32]="welcome to my nios2 world";
alt_dma_txchan tx;
/* Obtain a handle for the device */
if ((tx = alt_dma_txchan_open ("/dev/dma")) == NULL)
printf ("Error: failed to open device\n");
exit (1);
else
/* Post the receive request */
alt_dma_txchan_ioctl(tx,ALT_DMA_TX_ONLY_ON,UART_BASE);
if (alt_dma_txchan_send (tx, buffer, 32, dma_done, NULL) < 0)
printf ("Error: failed to post receive request\n");
exit (1);
/* Wait for the transaction to complete */
while (!dma_complete);
printf ("Transaction complete\n");
alt_dma_txchan_close (tx);
return 0;
--- Quote End ---
--- Quote Start ---
nios2-terminal: connected to hardware target using UART on /dev/com1 at 115200 b
aud
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
rrnnaattoo ooppeeee
--- Quote End ---
