DMA
Hello
I have problem with the DMA controller
So, i have 2 memory and with the DMA i would like to transferer data from the first memory in the second.
When i declare the DMA i have to paste node read_master and write_master to each memory but i can so how can i do
thanks
Can u explain better your problem?u are in SOPC builder envoironment, ok?what kind of memory are u using(onchip,external RAM,SDRAM)?what u are not able to do, connect teh read and write master to memory slave ports?
--- Quote Start ---
originally posted by soin@Jul 13 2005, 05:17 AM
hi,
can u explain better your problem?u are in sopc builder envoironment, ok?what kind of memory are u using(onchip,external ram,sdram)?what u are not able to do, connect teh read and write master to memory slave ports?
--- Quote End ---
so i have first the dpram (doucble access ram) and the second memory is a SRAM and i would like to read on the DPRAMand transfere the data to the SRAM
thanks
Hi..
It's a very simple,
You just connect DPRAM slave port with DMA Read-Master. It means that DMA Read Master can read data from dpram into DMA FIFO.
And connect SRAM slave port with DMA Write-Master. It means that DMA Write Master can write data of DMA FIFO to SRAM.
Regards.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
I&#39;m a beginner with DMA and I&#39;m working with Nios I. I&#39;m just doing this little test: reading data from external sram (a block of 64 positions) and writing it in a fifo (my user logic). My fifo is connected with Avalon in this way:
FIFO --> AVALON SIGNAL
ena --> chipselect } for writing
data -->writedata
wrreq --> write
rdreq --> read
clock --> clk
aclr --> reset
q --> readdata
full --> export } it turns on a led
The only problem is the first address of fifo, because when I read the data (with the traditional method, without DMA) written before with DMA, I get a zero in the first position (0) the first time I run the program. The next times, I get the value that it&#39;s supposed to be in the last position (63).
I&#39;m using nr_dma_copy_range_to_1.
Any help?
Thanks a lot!
I tested with an Altera FIFO (with show-ahead option activated) and it&#39;s ok. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
The thing is that now I need another RAM but it can&#39;t be a FIFO: a control unit gives it the address for writing and RAM gets out the data sequentially if "NiosRead" is high. The problem is reading data from my module again: the first time is just fine, but the second time I run the program the first datum is repeated and the value# 8 is lost. Here is the VHDL code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY ram_idct_out IS
PORT(
NiosCS : IN std_logic;
NiosRead : IN std_logic;
NiosReset : IN std_logic;
clk : IN std_logic;
data_in : IN std_logic_vector (8 DOWNTO 0);
dir_w : IN std_logic_vector (5 DOWNTO 0);
write : IN std_logic;
data_out : OUT std_logic_vector (8 DOWNTO 0)
-- Declarations
END ram_idct_out ;
ARCHITECTURE flow OF ram_idct_out IS
-- Architecture declarations
TYPE memory_type is array (63 DOWNTO 0) of
std_logic_vector(8 DOWNTO 0);
SIGNAL memory : memory_type;
SIGNAL rd_addr : integer range 63 DOWNTO 0;
SIGNAL wr_addr: integer range 63 DOWNTO 0;
BEGIN
process0 : PROCESS (clk, NiosReset)
BEGIN
-- Asynchronous Reset
IF (NiosReset = &#39;1&#39;) THEN
-- Reset Actions
rd_addr <= 0;
data_out <= (OTHERS => &#39;0&#39;);
ELSIF (clk&#39;EVENT AND clk = &#39;1&#39;) THEN
data_out <= memory(rd_addr);
IF NiosRead = &#39;1&#39; AND NiosCS = &#39;1&#39; THEN
IF rd_addr = 63 THEN
rd_addr <= 0;
ELSE
rd_addr <= rd_addr + 1;
END IF;
END IF;
IF write = &#39;1&#39; THEN
memory(wr_addr) <= data_in;
END IF;
END IF;
END PROCESS process0;
-- Architecture concurrent statements
wr_addr <= conv_integer(unsigned(dir_w));
END flow;
Could you please help me? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif Thanks!!!!
By the way, I have to add another DMA for reading, I thought that it could work out with only one (for writing and reading).
