DMA
i use a dma CRC peripheral.when i run as NIOS II MODELSIM ,THE SIMULATE result is correct,but I run as the NIOS II hardware ,the result is wrong .why this results is not indential.
i use quartus 5.0 and nios II 5.0 build 73c,if i use DMA HAL,the SIMULATE result is wrong.TOO.WHY?
HELP ME.THANKS.
this is my verilog soure
module crc_peripheral ( reset, clk, chipselect, write,read,
writedata, address, readdata);
input reset;
input clk;
input chipselect;
input write;
input read;
input [31:0] writedata;
input address;
output reg [31:0] readdata;
reg [15:0] crc_result;
reg [15:0] crc_reg;
// Set result output
//assign readdata = {16'h0, crc_reg};
// Initialise or update CRC reg based on address line
wire [15:0] crc_reg_input = (address) ? crc_result : writedata[15:0];
// CRC needs big endian data but Nios is little endian
// Convert data here
wire [15:0] crc_word = {writedata[7:0], writedata[15:8]};
wire [15:0] next_crc_word = {writedata[23:16], writedata[31:24]};
// CRC calculation
integer i;
reg [15:0] crc_array[0:16];
always @ (crc_word, next_crc_word)
begin
crc_array[16] = crc_reg;
for (i=15; i>=0; i=i-1)
begin
crc_array [0] = crc_array [i+1][15] ^ crc_word
crc_array [1] = crc_array [i+1][0];
crc_array [2] = crc_array [i+1][1];
crc_array [3] = crc_array [i+1][2];
crc_array [4] = crc_array [i+1][3];
crc_array [5] = crc_array [i+1][4] ^ crc_array [0];
crc_array [6] = crc_array [i+1][5];
crc_array [7] = crc_array [i+1][6];
crc_array [8] = crc_array [i+1][7];
crc_array [9] = crc_array [i+1][8];
crc_array [10] = crc_array [i+1][9];
crc_array [11] = crc_array [i+1][10];
crc_array [12] = crc_array [i+1][11] ^ crc_array [0];
crc_array [13] = crc_array [i+1][12];
crc_array [14] = crc_array [i+1][13];
crc_array [15] = crc_array [i+1][14];
end
crc_array[16] = crc_array[0];
begin
crc_array [0] = crc_array [i+1][15] ^ next_crc_word
end
crc_result <= crc_array [0];
end
// CRC Register
always @ (posedge clk or posedge reset)
begin
if (reset)
crc_reg <= 0;
else
if (write && chipselect)
crc_reg <= crc_reg_input;
end
begin
if (reset)
readdata <= 0;
else
if (read && chipselect)
readdata <= {16&#39;h0,crc_reg};
end
endmodule
this is my c program
volatile alt_u16 crcCompute(void)
alt_u16 word;
int value;
int pat[4]={0x00000003,0x00000004,0x00000005,0x00000006};
//alt_u8 pat[8]={0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x04};
int mode;
//pat[0]=0x00000003;
printf("start crc\n");
IOWR(CRC_PERIPH_BASE,0,0x0000FFFF);
//value=IORD(CRC_PERIPH_BASE,0);
//printf("value= %x\n",value);
// value=IORD(CRC_PERIPH_BASE,1);
/*IOWR(SLAVE_REG_0_BASE,0,0x0000F0F0);
alt_dma_txchan_ioctl(tx,
ALT_DMA_TX_ONLY_ON,
(void*)(CRC_PERIPH_BASE+0x4 ));
alt_avalon_dma_send (tx,
(int)pat,
16 ,
//dma_done,
NULL,
NULL);*/
IOWR_ALTERA_AVALON_DMA_STATUS(AVALON_DMA_BASE, 0);
IOWR_ALTERA_AVALON_DMA_CONTROL(AVALON_DMA_BASE,0);
IOWR_ALTERA_AVALON_DMA_RADDRESS(AVALON_DMA_BASE, (int)pat);
IOWR_ALTERA_AVALON_DMA_WADDRESS(AVALON_DMA_BASE, (CRC_PERIPH_BASE+0x4));
IOWR_ALTERA_AVALON_DMA_LENGTH(AVALON_DMA_BASE, 4);
mode =
ALTERA_AVALON_DMA_CONTROL_WORD_MSK |
ALTERA_AVALON_DMA_CONTROL_GO_MSK |
ALTERA_AVALON_DMA_CONTROL_LEEN_MSK |
ALTERA_AVALON_DMA_CONTROL_WCON_MSK ;
IOWR_ALTERA_AVALON_DMA_CONTROL(AVALON_DMA_BASE,mode);
while (IORD_ALTERA_AVALON_DMA_STATUS (AVALON_DMA_BASE) &
ALTERA_AVALON_DMA_STATUS_BUSY_MSK);
printf("waiting crc\n");
word = (IORD((CRC_PERIPH_BASE),1));
printf("crc value0=%x\n",word);
word = (IORD((CRC_PERIPH_BASE+0x1),1));
printf("crc value1=%x\n",word);
word = (IORD((CRC_PERIPH_BASE+0x2),1));
printf("crc value2=%x\n",word);
word = (IORD((CRC_PERIPH_BASE+0x3),0));
printf("crc value3=%x\n",word);
word = (IORD((CRC_PERIPH_BASE+0x0),0));
printf("crc value4=%x\n",word);
word = (IORD((CRC_PERIPH_BASE+0x1),0));
printf("crc value5=%x\n",word);
word = (IORD((CRC_PERIPH_BASE+0x2),0));
printf("crc value6=%x\n",word);
printf("crc value7=%x\n",word);
word = (IORD((CRC_PERIPH_BASE),0));
printf("crc value00=%x\n",word);
return (word);
} /* crcCompute() */
