12747 Discussions
Defining Device in Eclipse for HWlibs
AShiv
As the question states I am having trouble defining the device in the eclipse DS-5 Arm client for use with HWlibs. I understand I have to add a preprocessor macro with the device, in my case soc_cv_av, but they changed the way the macros are added in eclipse. Here is the old way and how it looks in all the Altera guides found online:
However I suppose at some point they changed the interface since much of the project build setting are different so now it looks like this:
Requiring a symbol as well as a value. I've tried:
Symbol: -D      Value: soc_cv_av
Symbol: -d      Value: soc_cv_av
Symbol: ALT_DEVICE_FAMILY      Value: soc_cv_av
Symbol: soc_cv_av      Value: soc_cv_av
None of which did anything about the error. It's extremely frustrating. I was able to run a simple hello_world without HWLIBS but now as I am getting into using the bridges I need those files. I appreciate any help thanks!
FawazJ_Altera
Which DS-5 version are you working with, plus which GHRD version is that?
FawazJ_Altera
I would like to know if you could manage to solve your issue.
thanks
AShiv
Hi FJumaah, sorry I thought I had responded to this. I was using DS5 5.28, GHRD was the one that came with Quartus 18.0. I cant remember the exact version of it though. I came up with a work around by using a makefile based project instead of a Eclipse managed one. Thanks though!
