12748 Discussions
Delayed ethernet packet processing (bug?)
As reported to bugzilla:
If the priority of the ethernet driver thread is lower (higher# ) than the FreeBSD Network Thread, then the Network Thread can get prematurely woken up to process an incoming ethernet pkt before the packet is fully enqued. Specifically:
if_ethersubr:ether_demux() calls schednetisr() (which wakes up network thread) prior to the pkt being enqued with that call to IF_ENQUEUE().
This might not be obvious because a subsequent incoming packet can (partially) process the queue.
One solution is to make sure the thread priority of the ethernet driver Handler_RxEvent() is higher (lower# ) than the FreeBSD Network Thread (default 7). A kludge option is to call both:
schednetisr(2/*or NETISR_IP*/);
schednetisr(18/* or NETISR_ARP*/);
after each recv packet is processed by the Handler_RxEvent() call.
Actually, this seems to be a problem if any network thread calling select(), such as tftp and probably most others, are at a lower priority (higher# ) than the FreeBSD Network Thread.
