I modified kernel configuration to enable uart for output kernel message. But after this message expand: from=/ramfs.img to=/dev/ram1 I don't see anything. I made change in inittab file to enable uart for stdout message. So it doesn`t fix the problem Any idea? ChristianLink Copied
Did you try the advice from this post?
http://www.niosforum.com/forum/index.php?a...=1289&hl=agetty (http://www.niosforum.com/forum/index.php?act=st&f=18&t=1289&hl=agetty) Jon
