Downloaded File on kit
I have a small c program (about 10KB) and I use the SDRAM as the program memory,heap,...etc. When I build my project, it says :
Linking Cfile.elf... 380KB (code+initialized data) & the rest of free memory in the SDRAM.
That makes a problem for its big size when storing it in memory (if I wanted to use memory bits for example). Why does the file have this big size?
