hi, I have an only EPCS4 on my cyclone board (1c12) and I want to program EPCS4 but i fail.
<div class='quotetop'>QUOTE </div> --- Quote Start --- #! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd E:/gxh/flashOnePIO/flashOnePIO/software/hello/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=E:/gxh/flashOnePIO/flashOnePIO/xby. sof --output=xby.flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=xby.op t E:/gxh/flashOnePIO/flashOnePIO/xby.sof xby.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Fri Sep 15 12:05:44 2006 Info: Elapsed time: 00:00:03 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert xby.pof xby.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Fri Sep 15 12:05:46 2006 Info: Elapsed time: 00:00:01 # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x01201038 --id=1622478268 --t imestamp=1158289160 --epcs --base=0x01000000 xby.flash Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x01201038: verified No EPCS layout data - looking for section [EPCS-FF] Unable to use EPCS device Leaving target processor paused # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --epcs --after=xby.flash --input=hello.elf --outpu t=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_load er_epcs.srec # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x01201038 --id=1622478268 --t imestamp=1158289160 --epcs --base=0x01000000 epcs_controller.flash Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x01201038: verified No EPCS layout data - looking for section [EPCS-FF] Unable to use EPCS device Leaving target processor paused[/b] --- Quote End --- What could I do ? please help me. Thank you.Link Copied
Hi Snowfox!
I've got the same problem with ep1c6 and epcs4. Although, I had no problem at all with ep1c12 with epcs4. Everything is under nios 5.1 Have you solved the problem?- Mark as New
I had the same problem when I received my target board and it turned out to be a cold solder on the EPCS device on my board. So I would assume your EPCS device is either not working or not connected properly to you FPGA.
