EPCS processing - help please
I have a system where epcs save HW+SW so my nios is working fine (programm stars - no problem)
but i can't get access to epcs - because alt_avalon_spi_comman hangs during processing
I use HAL
Give me please working example for it or correct my code.
I don't understand what i do wrong.
switch(getchar())
case 's': case 'S':
fram();
break;
case 'e' : case 'E':
printf("n\reading status of epcs");
printf("n\nstatus: %x",epcs_read_status_register(EPCS_CONTROLLER_BASE));
default:
continue;
i've used EPCS1 and EPCS4 in a design, reading and writing it in software. Have u first call the fuction alt_flash_open_dev? Can u post all your code?
bye
I solve all problems .
I have in my board
SPI real time clock
2x SPI FRAM
All of them i connect to EPCS SPI bus
And i work with all devices using epcs controller core
I find in sources of EPCS controller that EPCS controller use standart SPI routines
but all of them where not work
after this
if look into epcs_controller.v and find this strings
assign epcs_select = chipselect && (address[8] ); // activation of epcs data
assign readdata = epcs_select ? data_to_cpu : rom_readdata; \\ switch between BOOT ROM data and epcs data
sofware for SPI was next # define IORD_ALTERA_AVALON_SPI_RXDATA(base) IORD(base, 0x00)
address[8] - is zero !!!!!!!!!!
and i fix it in all strings like this # define IORD_ALTERA_AVALON_SPI_RXDATA(base) IORD(base, 0x100)
And now all work just fine !
