I have a system where epcs save HW+SW so my nios is working fine (programm stars - no problem)
but i can't get access to epcs - because alt_avalon_spi_comman hangs during processing I use HAL Give me please working example for it or correct my code. I don't understand what i do wrong. switch(getchar()) { case 's': case 'S': fram(); break; case 'e' : case 'E': printf("n\reading status of epcs"); printf("n\nstatus: %x",epcs_read_status_register(EPCS_CONTROLLER_BASE)); default: continue; }Link Copied
i've used EPCS1 and EPCS4 in a design, reading and writing it in software. Have u first call the fuction alt_flash_open_dev? Can u post all your code? bye- Mark as New
I solve all problems .
I have in my board SPI real time clock 2x SPI FRAM All of them i connect to EPCS SPI bus And i work with all devices using epcs controller core I find in sources of EPCS controller that EPCS controller use standart SPI routines but all of them where not work after this if look into epcs_controller.v and find this strings assign epcs_select = chipselect && (address[8] ); // activation of epcs data assign readdata = epcs_select ? data_to_cpu : rom_readdata; \\ switch between BOOT ROM data and epcs data sofware for SPI was next # define IORD_ALTERA_AVALON_SPI_RXDATA(base) IORD(base, 0x00) address[8] - is zero !!!!!!!!!! and i fix it in all strings like this # define IORD_ALTERA_AVALON_SPI_RXDATA(base) IORD(base, 0x100) And now all work just fine !
