12748 Discussions
Error Building Binary Toolchian
I'm trying to build the binary toolchain. After building the binary toolchain I try to put the path to locate the tools, I follow the steps of NiosWiki and when I verify, it doesn't go.
I'm using ubuntu 9.04 and I introduce the path in /.bashrc for example :
PATH=$PATH:/home/Escritorio/Fpga/nios2-linux/toolchain-build/build/nios2/bin
If someone can give an idea, sorry for my ignorance I'm a noob.
Thanks a lot
put
--- Quote Start ---
--- Quote End ---
in ~/.profile
"~/" refers to your home directory. Same path for .bashrc
Thanks for the answer.
I have made what you say and it doesn't go yet. Aulthought I have continuo with the prebuilt binary toolchain, inserting the path the same as before and this time the terminal recogmize de command of nios' compiler.
Thanks for your help
Maybe you miss the line:
export PATH
Thanks a lot for the help. Now it goes
