12748 Discussions
Error in GDB server terminated with
Paul83
Hello everyone,
I'm currently working on a project using the Nios V processor on a Cyclone 10 GX. I've created the Nios V with the platform designer and generated the BSP. I'm using the Ashling RiscFree IDE to write a simple "Hello World" application.
The application compiles successfully without any issues. However, when I try to run it, I encounter an error that says "Error in GDB server launch sequence".
Has anyone else experienced this issue? If so, how did you resolve it? Any help or guidance would be greatly appreciated.
PS: I have checked another post to solve this issue by updating the IP. But my IPs are the latest version.
Thanks in advance,
Paul
khtan
Hi Paul,
Thanks for using Intel Support Forums.
Let me check on this with our database and will let you know later.
Kian
khtan
Hi Paul,
I've checked our database, looks like it is a known issue
https://www.intel.com/content/www/us/en/support/programmable/articles/000092621.html
From engineering notes, the issue is still open.
I saw that you're already using RiscFree 23.4.1 ? Just to confirm as the issue was reported on 22.2 so that I could feedback to engineering.
Alternatively there is a workaround given by engineering team previously whereby you can try performing Debug with boot from serial flash by “uncheck” the Load image option.
The rest of the settings is still the same.
Kian
Paul83
Hi Kian,
I try your advise and it seems it works. But even I checked the Load image box again, there is no problem
Thanks for your help.
Paul
khtan
Hi Paul,
Thanks for the update and glad it is working for you albeit strange it is working as well after you recheck the Load Image box again.
Anyway I already feedback to our engineering team based on your observation. Is there anything else I could help with on the case, otherwise I would like to close it and transition the thread to community support.
Kian
khtan
Hi Paul,
I will set this thread to close pending since the issue have been resolved. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Kian
