12745 Discussions
Error in NIOS Dev Kit, Reference Manual ?
Hi
I'm using Cyclone Development Board. I think that there is an errror in "Reference Manual" for that board. On figure 1-6 (page 1-13) pinout for connection betwen Cyclone and expansion connector J12 is not correct. I'm using MNL-N2DEVLBDCYC-1.1 manual.
In my opinion, it should be:
1- GND
3- V20
5- J19
7- H14
9- J17
11-K15
13-V18
2- +5V
4- J15
6- J20
8- J14
10-J18
12-W18
14-V19
I didn't find any aswer on Altera's web site. Could someone check it ???
Cheers
Michal
Hey Michal;
Your pinouts are almost correct with just one change pin 3 should be U20 not V20 so the correct pinout is:
1- GND
3- U20
5- J19
7- H14
9- J17
11-K15
13-V18
2- +5V
4- J15
6- J20
8- J14
10-J18
12-W18
14-V19
I am not sure how this got by us for so long but thanks for bringing it to my attention. Since that one is wrong I started checking the figure 1-5 and it looks wrong too. I will post once I have worked out the pinout for this one as well.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif Yikes!
The last release of the Cyclone board manual somehow included incorrect pinout information for the PROTO1 header. We just identified the issue and will have a corrected version posted to the web ASAP.
Note that this is not just an issue with J12. J11, J12, and J13 are all affected. I believe the PROTO2 header pinouts are unaffected, and the published pins are correct. You can use PROTO2 to get your work done.
I will update this thread when the updated document hits the web. Thanks for pointing out this issue with Altera documentation.
Matthew
The Nios Development Board, Cyclone Edition Reference Manual is now updated on the Altera web site.
Matthew
