12748 Discussions
Error processing nios2_system.h
Folks,
I am running into problems when generating nios2_system.h while building a kernel. The output from the builder (up to the point of failure) is:
------------------------------------------------ Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x&#39;  no emulation specific options.  Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x as source for kernel  GEN    /workspace/DataLoggingInterface/DLI_kernel/build/Makefile  CHK     include/linux/version.h  SYMLINK include/asm -> include/asm-nios2nommu  CHK     include/nios2_system.h Can&#39;t call method "getAssignment" on an undefined value at /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/scripts/PTF/SystemPTF/Module.pm line 207, <STDIN> line 6121.
I have attempted to build the system PTF file many times, yet the kernel builder is still running into difficulty.
Any help would be appreciated.
Michael
You&#39;d better work on Linux and follow the Nios wiki.
building the kernel works well on Linux as well as the Windows Altera IDE.
Therefore the problem must be in your ptf file.
