I am running quartus2 and nios2eds in windows.
i was unable to Create a New Nios II Application and BSP from Template. the error was unable to create project Reason: Failed to execute: ./create-this-app --no-make chmod: changing permissions of `.': Permission denied chmod: changing permissions of `./create-this-app': Permission denied some one help me:confused:Link Copied
One of the early mistakes that I made was to use filenames with spaces (like 'My Documents\My Projects\Nios II Test'). No spaces are allowed and there is no error message stating this limitation.
Bill- Mark as New
Try running the SBTs as administrator. (Right clock on the shortcut and select "Run as Administrator".)
As u said i run SBT as administrator, it is working :)
thank u for ur reply.
