12747 Discussions
Error while generating nios ii BSP
Dheeraj_kumar
With the latest eclipse i.e.
Version: Mars.2 Release (4.5.2)
Build id: 20160218-0600
when I am trying to generate a new BSP with sopcinfo file I am facing this error (attached below).
error: nios ii bsp wizard failed. create, generate and edit BSP using BSP editor, then import as Nios II software Build tools project.
when I try to create BSP with BSP Editor, I am not able to generate .project file due to which the generated BSP is not able to be used or imported into project.
contents of new BSP with BSP Editor:
contents of BSP created directly:
Dheeraj
KennyTan_Altera
Hi, Kindly expect some late reply as the owner is taking some leave until next week.
EBERLAZARE_I_Intel
What was the Quartus / Nios II Eclipse version that you were using?
Dheeraj_kumar
Quartus version: 21.4 lite
Eclipse version: Mars.2 Release (4.5.2)
EBERLAZARE_I_Intel
Can you upload here your design file? I will try to run it on my side.
EBERLAZARE_I_Intel
Any update from your side?
Dheeraj_kumar
I will share the zip file with in couple of days
EBERLAZARE_I_Intel
Thanks!
EBERLAZARE_I_Intel
Are you still facing the issue?
