12606 Discussions
Errors Building Redboot for EP2C35 Dev Board
Hello:
I am currently trying to build Redboot for the Cyclone II 2C35 Development Board. Two errors are being reported during the link phase:
1. undefined reference to perror in altera_avalone_lan91c111.inl.
The code is shown below. Does ALTERA_NIOS_DEV_BOARD_CYCLONE_2C35 need to be added to the# if defined list or can I just comment out the reference to perror?
/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/extras.o(.text.altera_avalon_lan91c111_get_esa_wrapper+0x88): In function `altera_avalon_lan91c111_get_esa_wrapper':
/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/include/cyg/sopc/altera_avalon_lan91c111.inl:112: undefined reference to `perror'
/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/extras.o(.text.altera_avalon_lan91c111_get_esa_wrapper+0x94):/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/include/cyg/sopc/altera_avalon_lan91c111.inl:113: undefined reference to `perror'
/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/extras.o(.text.altera_avalon_lan91c111_get_esa_wrapper+0xa0):/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/include/cyg/sopc/altera_avalon_lan91c111.inl:114: undefined reference to `perror'
From ../altera_avalon_lan91c111\current\include\altera_avalon_lan91c111.inl:
# if defined(ALTERA_NIOS_DEV_BOARD_CYCLONE_1C20) ||
defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10) ||
defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10_ES) ||
defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S40)
HAL_READ_UINT32 ((void*) (LAST_FLASH_SECTOR), signature);
if (signature != 0x00005afe)
diag_printf("This Flash does not contain a valid MAC Address\n");
memcpy(enaddr, static_esa, 6);
diag_printf("Using the default of 0x%x:%x:%x:%x:%x:%x\n", enaddr[0], enaddr[1], enaddr[2],
enaddr[3], enaddr[4], enaddr[5]);
else
HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 4), enaddr[0]);
HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 5), enaddr[1]);
HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 6), enaddr[2]);
HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 7), enaddr[3]);
HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 8), enaddr[4]);
HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 9), enaddr[5]);
}# else
diag_printf("This is not an Altera development board\n");
perror( "Not an Altera board.\n");
perror( "You need to modify the function altera_avalon_lan91c111_get_esa() \n");
perror( "to set a MAC address for your board");# endif /* (Altera Nios Dev board definition) */
2. Global Pointer out of range
/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/libtarget.a(redboot_main.o)(.text.do_idle+0x14): In function `valid_address':
/cygdrive/c/altera/kits/nios2/components/ecos/ecos-current/packages/redboot/current/src/main.c:756: Unable to reach __RedBoot_IDLE_TAB_END__ (at 0x04000dd0) from the global pointer (at 0x04008e2c) because the offset (-32860) is out of the allowed range, -32678 to 32767.
collect2: ld returned 1 exit status
make[1]: Leaving directory `/cygdrive/c/Projects/GenOne/Software/eCos/redboot_build/redboot/current'
make[1]: *** [/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/bin/redboot.elf] Error 1
make: Leaving directory `/cygdrive/c/Projects/GenOne/Software/eCos/redboot_build'
make: *** [build] Error 2
else
}# else
Any thoughts?
TIA
About first problem,
I have a same problem , It looks likes this eCos configurator supported only few models about below.
My case was ALTERA_NIOS_DEV_BOARD_STRATIX_2S60_ES board. so I simply add "defined(ALTERA_NIOS_DEV_BOARD_STRATIX_2S60_ES) || \"
#if defined(ALTERA_NIOS_DEV_BOARD_CYCLONE_1C20) ||
defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10_ES) || \
#defined(ALTERA_NIOS_DEV_BOARD_STRATIX_2S60_ES) || \
#defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S40)
aqura http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
aqura:
Thank you for your reply. That is what I thought. However I was reluctant to add the test for the 2C35 board since it was included elsewhere in the code. I will add and rebuild.
As for my second error, from this forum (and others) I have added "[]" to the following statements in main.c to modify the addressing from relative to absolute.
From: extern struct init_tab_entry __RedBoot_INIT_TAB__[], __RedBoot_INIT_TAB_END__;
To: extern struct init_tab_entry __RedBoot_INIT_TAB__[], __RedBoot_INIT_TAB_END__[];
Thanks again...........
Graham.....
I am also trying to build RedBoot for a Cyclone-II 2C35.
I have had many of the same problems like yours and I have been using the suggested fixes but I just keep getting to some other error.
Did you or anyone else get Redboot to build for the Cyclone-II 2C35?
We are in the process of getting the ecos update for Nios II 5.1 ready to go -- this will be addressed in that release.
