12748 Discussions
Execute-in-place with Generic Serial Flash controller and Nios V
JohnJLF
Does anyone have a link for an application note or reference design using a NiosV, generic serial flash controller and execute-in-place from flash memory
I managed to run my application using NiosV and the old serial flash controller (serial flash controller II). However,  when I change the flash controller to the generic serial flash controller it does not work.
Any idea/help is very welcome and appreciated.
EBERLAZARE_I_Intel
It is this one:
https://www.intel.com/content/www/us/en/docs/programmable/726952/23-4/nios-v-processor-design-configuration-49895.html
You set your flash device in the GSFI IP settings including when you try to generate the .jic file at the end of the chapter.
JohnJLF
Many thanks. I will follow the instructions.
JingyangTeh_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
