FileI/O in NIOSII IDE
I've got a question about FileI/O in NIOSII IDE.
I'm working on open source JPEG running on NiosII processor.
Mostly, I'm working on NiosII IDE. I'm using Advanced project in NiosII IDE which I required to create/ manage 'makefile' to compile the project.
After successful compilation, NiosII IDE generated excuteable.
And I need to run it with parameters. For example,
'jpeg' is the excutable name. And it requires two parameters.
=> jpeg [input file] [output file]
But when I clicked "run", it run "jpeg" only. How can I do this task?
input file is existing file and output file is non existing file/expected to be generated when it run successfully.
Could you give me guidance how to deal with this task, please?
Or is there any document/tutorial which related to file I/O in NiosII IDE?
Thanks in advance,
Yong.
