Filesystem Sync w/ FTP
I'd like to update files on my onboard flash via FTP. I have my flash mounted as ext2 at startup. I can FTP to the board and send my files, but I can't find a way to synchronize the filesystem without a command line (via telnet or JTAG -- by issuing 'sync'). In production a command line is out of the question. Without a sync, the filesystem becomes corrupt on a reboot or power cycle. So, questions:
1) Is there a way to issue a 'sync' command via a Windows FTP client to the Nios FTPD? I'm guessing no after a cursory inspection of the cl options.
2) If no, any recommendations? Surely someone else needs this. Where can I get the source to Nios ftpd? Is it stock GNU code? Is there a different FS type that would have this problem?
Thanks in advance,
Ryan
Quantapoint
Hi rfrenz,
Can you use jffs2 rather than ext2? I believe it handles such issues by design.
--Scott
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Can you use jffs2 rather than ext2? I believe it handles such issues by design.[/b]
--- Quote End ---
This works. Thanks, Scott.
