12748 Discussions
Flash Programmer with CFI Flash
Hi folks,
perhaps someone can help me here, i have a Altera Cyclone III Starter Board, with an CFI Flash. The following IPs are included in my configuration:
ext_flash at base 0x01000000 and end 0x01ffffff (flash memory interface)
ssram at base 0x03100000 and end 0x031fffff (Cypress CY7C1380C SSRAM)
flash_ssram_tristate_bridge
clock_crossing_rup for the remote_update_controller
buttons and leds
jtag_uart and of course a NIOS II
reset vector is in ext_flash at 0x00100000
exception vector is in ssram at 0x20
What i want to do is this:
1. create a factory image .sof with a corresponding .elf file
as well as an application image .sof and an elf file
2. convert these files to .flash and programm them into the flash-memory
3. restart the board, start with factory image and switch to the application image and switch back to factory image
4. update the application-image while running factory-image (in later usage there will be a usb-driver in the factory image so that i have an other application on PC-side which transfers the .flash file of application hard- and software to the factory image, which than should write the new image into flash)
Problems :( :
how do i update the flash via software? ...just use the driver of the flash and write to the corresponding registers?
Thanks, Christian
PS: i overlooked the AN521, AN548 and AN458 ...thanks for help.
