Flash Programmer!
Hi,hippo
I following WiKiHome's "Flash Programmer Guide" try out flash.
I have to test the new kerenl image with nios2-download.
Don't run nios2-terminal, use Hyper-terminal on Windows.
Make sure it runs correctly over the RS-232C COM port.
It'sOK!
But when i programmer image on EPCS flash,than power up my Hyper-terminal message has no any message.
What's problem?
I make sure "sof file" it already program on EPCS flash.
I have a doubt, when i want to program "sof on EPCS flash" and "image on CFI flash" how to select "reset address"?
Can you give me some hint?
PS: my dev board is DE2.
Thank you very much!
NiosQ
Hi NIOSQ:
You have to select your reset addres in SOPC Builder when building the NIOS system. There you must set it to point to CFI flash.
I hope this helps,
Luis
--- Quote Start ---
originally posted by luisalba@Mar 27 2007, 02:14 AM
hi niosq:
  you have to select your reset addres in sopc builder when building the nios system. there you must set it to point to cfi flash.
i hope this helps,
luis
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22535)
--- quote end ---
--- Quote End ---
Hi,luisalba
Thank you for your reply.
I look "nios2_systems.h" found my EPCS flash can uses space only 800KB,so I thank the size is to small , my build "sof file is 310KB" and "image file is 1300KB".
Anyone know howe to increase EPCS flash size?
NiosQ
I have just updated the wiki page with more details. Please check.
--- Quote Start ---
originally posted by hippo@Mar 27 2007, 11:18 PM
i have just updated the wiki page with more details. please check.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22574)
--- quote end ---
--- Quote End ---
Hi,hippo
Can you give me DE2_NET v1.4a project?
My project is DE2_NET v1.1
Please!
NiosQ
--- Quote Start ---
originally posted by hippo@Mar 28 2007, 02:17 AM
you can use v1.5, it should be the same.
ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip (ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22579)
--- quote end ---
--- Quote End ---
Hi,hippo
It&#39;s work!!!
Thank you very much.
I try out it many day.
I deeply appreciated your helped, because you it just can work!
Thx!
NiosQ
