Hi, everybody
I'm newbie for niosII uClinux. I want NiosII boot from CFI Flash but I open NIOSII Command Shell can't find "cd arch/nios2nommu/boot" dir. Is my NIOSII Command shell has some problem? Need you help! thank you for your give me some suggest! NiosQLink Copied
- « Previous
- 1
- 2
- Next »
Thank you very much!
I try out RS232 serial UART now! Thx again!! NiosQ- Mark as New
--- Quote Start --- originally posted by hippo@Mar 22 2007, 10:21 PM the reset address in sopc builder has nothing to do with uclinux.
if you want to boot uclinux from epcs, select epcs as reset address.
if you want to boot from cfi flash, select cfi flash as reset address.
first, you should make rs232 work using jtag download.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22449)
--- quote end ---
--- Quote End --- Hi,hippo I'm write a simple program tested rs232 serial port, it's ok! I want to boot uclinux from epcs, but when DE2 powerup my rs232 no any message. How to solve this problem? PS: if i want to boot sof from epcs and boot uclinux from cfi flash the "reset address" and "kernel menuconfig"how to select? help me! NiosQ
- « Previous
- 1
- 2
- Next »
