Ftpd error
I have problems with the ftp and I don't know why because before it worked. I work with ubuntu 9.04 and de2-70. When I write the command ftp and the ip destination I receive this error in my host computer:
root@WORKGROUP:/home/garcia# ftp 192.168.1.10 Connected to 192.168.1.10. ftpd: invalid option -- w
Then If I write the command netstat in my target I can see that a ftp communication has received but has finished with the advice of FIN_WAIT2.
If someone can suggest me something.
Many thanks
To Vikonilov
I saw your post about interrupt using button.
I meet same problem right now.
Is it possible to share the code?
Thank you very much.
Best Regart
Hi vikonilvo,
I checked ftpd with test-nios2 and nios2mmu and didn't see the same issue using centos5. Is this a ubuntu issue?
- Hippo
Yes, I think that it is an ubuntu issue. I have changed something (I don't know what) and now I don't know how to configure properly.
Many thanks for the patience
Hi Vikonilov,
My Level is not enough to send Private Messages @@
My Mail is htmin2001 in gmail
Thank you very much
