as I want to develop software for the NIOS2/uClinux under a Linux operating system I'm looking for a working cross-compiler. After the GCC is used for Windows and this compiler is licensed under the GPL the sources should be available for free - but where? ElmiLink Copied
They are on the NIOS2 CD's...
If you ask your Altera FAE nicely you get them... rick- Mark as New
Okay...had mercy with you (o;
You can download at my website the sources taken from the Linux CD and prepacked together... Sources: http://www.fpga.ch/ (http://www.fpga.ch/) For build instructions go to my other website (o; http://www.uclinux.net/forum/viewtopic.php?t=116 (http://www.uclinux.net/forum/viewtopic.php?t=116) But for uClinux support..how about asking Microtronix releasing uClibc/elf2flt sources? (o; rick
