I build the nios2_60 source thisweek, but I got one error
always. Build gcc was success, but the newlib fail with message: ------------------------------------------------------------------------ . . . make[3]: Entering directory `/cygdrive/e/TEMP/build/newlib/nios2-elf/mno-hw -mul/newlib' make[3]: *** No rule to make target `all'. Stop. make[3]: Leaving directory `/cygdrive/e/TEMP/build/newlib/nios2-elf/mno-hw- mul/newlib' make[2]: *** [multi-do] Error 1 make[2]: Leaving directory `/cygdrive/e/TEMP/build/newlib/nios2-elf/newlib' make[1]: *** [all-multi] Error 2 make[1]: Leaving directory `/cygdrive/e/TEMP/build/newlib/nios2-elf/newlib' ------------------------------------------------------------------------ src download from http://nioswiki.jot.com/crossgcc (http://nioswiki.jot.com/crossgcc) build on Win2K with Cygwin build command with "../../src/newlib/configure --target=nios2-elf --prefix=/nios2" The message seem like not Makefile in that there, I download the newlib-1.14.0 & merge Nios2 support to it, but same error again. I checked the "config-ml.in", gcc build's Makefile & newlib's, but I do not found problem. Can anyone tell me how to build the newlib for Nios2? Thanks! ps: I build that on Linux no problem now. I will check the configure script this day.Link Copied
