GUI-less kernel building
I'm trying to automate the building of my kernel via a custom script, which will do the following:
1. copy my local edited kernel source files into the remote kernel directory
2. build the kernel
3. create vmlinux.bin
4. bin2flash
5. flash the board
I've got all of this in a bash script, but I cannot find how to accomplish step 3 (creating vmlinux.bin from 'vmlinux'). This is handled via the Eclipse plug-in normally (while the output window shows only the output of 'Make'). I was hoping someone knew which script was running under the hood here, so I can emulate this behavior in my bash routine.
Ryan
Quantapoint
This should do the trick:
nios2-elf-objcopy -O binary vmlinux vmlinux.bin
Thanks atlenisse, that's exactly what I was looking for.
Ryan
Quantapoint
