12748 Discussions
Getting System.h to list base of dual port onchip RAM
I have a project with dual port on-chip ram. One of the ports is accesible from the NIOS II. "system.h" has no information about the memory. I would like to get the base address and hopefully the span from "system.h".
Does anyone know how to get "system.h" to include this information?
Important portion from my ptf file:
Entry onchip_ram/s2 { address = "0x00000000"; span = "0x00008000"; is_bridge = "0"; }
EDIT:
I'm using 9.0SP2 for the NIOS IDE and Quartus. I would rather not upgrade because the environment is setup on multiple systems.
I had the same problem, and it is a bug in SOPC builder (or more precisely in the gtf scripts).
The dual port RAM will only show up in system.h if the first slave port is connected to the Nios CPU.
Unfortunately, I figured that was the problem. I'll have to change that and recompile the design later.
Thank you,
Jeff
