12748 Discussions
HAL, LWIP and fragmentation support
Dear all,
I'm taking a look to the LWIP source code, and in particular to the web server example for the Altera HAL distributed in the Forum .
In particular, I'm looking to the ip_reass_timer() function, called inside main().
here is the main loop:
    while(1)     { //0.6.4  lan91c111if_service(netif);  lan91c111if_service(&netif);    now = get_milliseconds();  if (now - lasttime > TCP_TMR_INTERVAL) {      lasttime = now;      tcp_tmr();      if (++i==50) {    //etharp_tmr();    i=0;      }      } # if IP_REASSEMBLY      if (++j==1000) {        ip_reass_timer();        j=0;      }    # endif       }
The reassembly timer is here (see src/core/ipv4/ip_frag.c):
void ip_reass_timer(void *arg) {  (void)arg;  if (ip_reasstmr > 1) {    ip_reasstmr--;    sys_timeout(IP_REASS_TMO, ip_reass_timer, NULL);  } else if (ip_reasstmr == 1)  ip_reasstmr = 0; }
it seems to me that the reassembly timer should be called once a second (IP_REASS_TMO is 1000).
Is that right?
PJ
